Chain + Cog problem
I've recently changed my chain and chainring and since then, it seems like my chain's been 'sticking' to the cog. It's strange and it creates a lot of noise. I've greased my chain and the noise is still there.
June 27, 2013 02:18 AM
AznChiliSauce
It could be the wrong size chain, chain ring, or cog.
You might even have your chain too tight or you pulled the wheel to one sider more so than the other.
June 27, 2013 02:54 AM
It's weird cause the chain wraps around the chainring without a problem but when a certain part of the chain passes the cog, it becomes really tight. It's only that one part of the chain that causes noise.
June 27, 2013 03:49 AM
AznChiliSauce
flex your chain sideways, you probably have a stiff parts in the chain, or a tight spot in the chainring when you put on a new chainring (chainring not align with the crank)
June 27, 2013 04:21 AM
Hm, that might be it. I'll do that soon and let you know what's up.
June 27, 2013 05:02 AM
AznChiliSauce
Your chain tension is too tight and unless you are using a very high quality chainring, I would guarantee it isn't perfectly round, causing a tight spot as it rotates. Even if your chainring is round, it may be off center (read [url=http://velowoodcyclery.wordpress.com/20...]).
June 27, 2013 12:58 PM
It gets stuck on the cog like so...
June 27, 2013 04:31 PM
AznChiliSauce
Get a Izumi Economy chain.
June 27, 2013 05:34 PM
Changed my rear wheel to a b43 laced to a Miche Primato hub with an 18t Phil wood cog. (Bike anchor) It's deadly silent now. Thanks for the suggestions guys!
June 27, 2013 05:52 PM
AznChiliSauce
could be a case of:
3/32 chainring
3/32 chain
1/8 cog.
if your chain wasnt new id say a ridiculously stretched chain.
June 30, 2013 03:01 AM
