Halo Track Hubs
What are peoples opinions on the Halo track hubs or complete wheels?? rear mainly?
February 9, 2012 11:09 PM
splined or threaded?
February 9, 2012 11:42 PM
snorky
if you have opinions on both that would be great!
i know the splined one means youd get a better chainline...but im just onabout performance!
February 10, 2012 11:08 PM
well benson. what i was saying is. with the splined youll be able to get a good chainline with what ever crank/front ring set up you have as your able to possition your rear cog to where ever you need it to.
February 10, 2012 11:39 PM
I used to have a halo laced to a DP18, it felt like any other of my wheels. (Origin 8/Formula laced to DP18)
And Benson, I've a question about chain line adjustment. My cog is more to the non-drive side(left) about maybe, 5-7mm? I did my studies and just to make sure, I just get a smaller spacer thing on the right side, and a slightly bigger one on the non-drive side, correct? So that it'll shift over to the right side a little to straighten the line. I can't put a washer infront of the cog since I can't even get my cog off in the first place.
February 10, 2012 11:41 PM
weetannggg
