What is a Rising Stem Gate Valve?
A Rising Stem Gate Valve is a type of gate valve that has the stem fixed to the disc.
It can follow the opening/closing position by moving the stem up and down, can be monitored electronically by adding a monitoring key, and does not obstruct the flow when fully open.
Threads on rising stem gate valves are located on the outside of the valve body. The amount of exposed stem makes it simple to determine whether the valve is open or closed. The valve is closed when the handle is flush with the pipe (no exposed stem). The valve is open if a large number of stems are exposed.
SVR Global is a leading rising stem gate valve manufacturer in USA that offers a wide range of Rising Stem Gate Valves. Our Rising Stem Gate Valves are tested to ensure that they meet all of our clients’ requirements. We also offer customized Rising Stem Gate Valves that are tailored to specific industrial demands.
Find us- https://svrglobal.net/products/rising-s...
Applications of Rising Stem Gate Valves:
SVR Global is a leading rising stem gate valve manufacturer in USA having the following applications-
Potable water applications
Wastewater
Water treatment and distribution systems
Mining industry
Shipbuilding and drilling facilities
HVAC systems
Description of Rising Stem Gate Valves:
Materials: Cast iron, Cast steel (WCB, WC6, LCB, WCC, LCC, WC9), Ductile iron, SS304, SS316
Class: PN10 to PN 450 ANSI 150 to 2500
Ends: Socket weld, Buttweld, Flanged, Threaded
Operations: Handwheel Operated, Gear Operated, Electric Actuated, Pneumatic Actuated
SVR Global is a world-leading provider of easy-installation critical flow control solutions that enable vital industries to operate safely, reliably, and more efficiently. With an experienced technical and service team in USA, SVR Global is a leading rising stem gate valve manufacturer in USA meeting all international standards including ANSI, API, ASME, AWWA, BS, DIN, GOST and JIS. You will find a large range of products on our website, in numerous sizes, styles, and designs. We also provide customized valves as per the requirements of the customers. If there is a valve you have questions about, or if you do not see a valve that meets your specifications, please contact our sales team for immediate assistance.
Visit us to know more about various valves provided by SVR Global - https://svrglobal.net/products/rising-s...
Wastewater
Mining industry
HVAC systems
