Specialized S-Works Adjustable Stems
Do you have any experience with this adjustable stem? Do they really work? I need stem that has 16 degrees.
http://www.ebay.co.uk/itm/SPECIALIZED-S-WORKS-ADJUSTABLE-BIKE-STEM-31-8mm-110mm-/282625500701?hash=item41cdcae61d:g:6tcAAOSwHsBZoTY9
August 28, 2017 06:58 PM
dara
its a shim that allows you to adjust rise.
August 28, 2017 11:35 PM
i have the stem on my MTB with the -16 and it works fine
August 29, 2017 12:41 AM
quinner
Dont these require a proprietary headset spacer or something?
August 29, 2017 12:59 AM
nope it should work on all bikes that are 1-1/8
August 29, 2017 01:44 AM
quinner
I've heard only good things about it
August 29, 2017 12:25 PM
ghostridethewhip
They're good stems, but a bit heavier than other stems because of the shim. There are various shims that you can get to adjust the angle and they do require a proprietary top cap that is offset.
August 29, 2017 01:46 PM
osiris419
67 bikes
