Forums > Marketplace >
FS: 4t Forti Titanium road frame 51cm CT 47.5cm CC
for sale beautiful 4t Forti titanium road frame build by the very same Victoria / 4T / Wittson brand company / builder https://wittson.com/custom-titanium-frame-builder .
Frameset comes in very clean condition with polished tubes all all in all quite a masterpiece. Comes WITHOUT 1 1/8" fork. No dents or cracks to the tubes. Nicely shaped chainstays and seat stays.
Measurements:
Seat Tube -
Center to Top - 51cm
Center to Center - 47.5cm
Top Tube - 53cm
Head Tube - 12.7cm
British threaded BB
Seatpost diameter 27.2mm
Weight 1,495kg
600 euros + shipping
May 6, 2019 05:14 PM
gintas_ce
Comes without the fork
May 18, 2019 06:49 AM
gintas_ce
The basic part of the magnetostrictive all kinds of sensor is the sensing element called the waveguide. The waveguide is made of ferromagnetic materials such as iron, nickel, cobalt and their alloys. The position magnet which is round in shape moves around this waveguide.
Initially when position has to be determined the Nagano keiki Pressure sensor electronics sends a current pulse called the interrogation pulse through the waveguide and starts the timer abs speed sensor . So a magnetic field is created around the waveguide. When the magnetic field of the position magnet interacts with the magnetic file around the waveguide a strain pulse is generated which travels at the speed of mazda 6 suction control valve on both sides. On one side this strain pulse is detected by the strain pulse detection system and then processed by the electronics and converted into electrical pulse suction control valve . The position is determined based on the time the strain pulse takes to Speed Sensor reach the strain pulse detection system. The un useful pulse which travels opposite Pressure Sensor the electronics is damped by damping module to prevent any interference by reflections from the waveguide tip.
Common Rail Pressure Sensor
Temperature Sensor
Fuel Metering Valve
Diesel Solenoid Valves
June 18, 2019 01:19 AM
piter85
up
August 13, 2019 05:57 AM
gintas_ce
