Soviet kharkov and izhevsk road and track parts:
NOS Kharkov front derailleur. 20 euros per derailleur
Soviet track and road spindles. 7 euros per spindle
Used Kharkov toe cages, clips. 5 euros per pair
Kharkov road hub. Special order. 36H. Front hub 100mm wide. Spins smoothly. No play. 30 euros
Soviet Kharkov 144 BCD 170mm road double chainring drive side crank. No damage to the threads. Retaped to 9/16x20. Cracked at the base of the spider. That was quite common issue and they were used regardless
10 euros
10 euros
10 euros
Soviet Kharkov 151 BCD 170mm road double chainring drive side crank. No damage to the threads. Retaped to 9/16x20. Cracked at the base of the spider. That was quite common issue and they were used regardless
10 euros
Soviet Kharkov 144 BCD 170mm track single chainring drive side crank. No damage to the threads. Retaped to 9/16x20. Cracked at the base of the spider. That was quite common issue and they were used regardless
15 euros
Nos Kharkov Chainrings 3/32" BCD 144 - 54t, 54t, 54t – 20 euros
Used Kharkov Chainrings 3/32" BCD 151 - 54t (drillium), 52t, 52t (drillium) - 20 euros
Used Kharkov Chainrings 3/32" BCD 144 – 54t, 52t (drillium), 51t, 50t, 49t, 47t - 15 euros per chainring
New Kharkov breakshoes - 5 euros per pair
Used Kharkov center pull brake caliper set 25 euros
Kharkov pedals M14x1.25 threads only left side - 5 euros per pedal
New Kharkov pulley wheels. 5 euros
Used Kharkov track cog 1/8 14t - 10 euros
NOS Kharkov freewheel 5 speed 13 - 17 teeth. 15 euros per freewheel
Kharkov shifters braze on. - 15 euros
+ shipping
[img]/f/34bec23a8b_1.jpg[/img][img]/f/34bec23a8b_2.jpg[/img][img]/f/34bec23a8b_3.jpg[/img][img]/f/34bec23a8b_4.jpg[/img][img]/f/34bec23a8b_5.jpg[/img]
10 euros
10 euros
10 euros
10 euros
15 euros
+ shipping
