Forums > Marketplace >
FS: Wittson titanium road frame 57cm
for sale beautiful Wittson titanium road frame build by https://wittson.com/custom-titanium-frame-builder .
Frameset comes in very clean condition with nicely polished tubes all in all quite a masterpiece. Comes with headset and 1" carbon columbus tusk air fork.
Measurements:
Seat Tube -
Center to Top - 57cm
Center to Center - 54cm
Top Tube - 54cm
Head Tube - 13cm
Italian threaded BB
Seatpost diameter 27.2mm
Total weight 2.20kg
650 euros + shipping
January 25, 2019 10:33 AM
gintas_ce
What’s rear tyre clearance like?
May 7, 2019 10:19 PM
i believe it's 28/32mm depending on the rim
May 8, 2019 05:23 AM
gintas_ce
600 euros + shipping
May 21, 2019 01:12 PM
gintas_ce
The inductive proximity sensor can be used to all kinds of sensor metallic targets only. The main components of the inductive proximity sensor are coil, oscillator, detector and the output circuit.
The coil generates the Nagano keiki Pressure sensor high frequency magnetic field in front of abs speed sensor the face. When the metallic target comes in this magnetic field it absorbs some of the energy. Hence the oscillator field is affected. This is detected by mazda 6 suction control valve . if the oscillation amplitude reaches a certain threshold value the output switches suction control valve .
The inductive proximity sensor works better with Speed Sensor ferromagnetic targets as they absorb more energy compare to non Ferromagnetic materials Pressure Sensor . Hence operating distance for sensor is more for Ferromagnetic targets.Suction Control Valve
NOX Sensor
Fuel pressure relief valve
Mass Air Flow Sensor
June 18, 2019 01:44 AM
piter85
FREE shipping via registered and insured airmail within EU
July 16, 2019 06:17 AM
gintas_ce
up
August 13, 2019 05:55 AM
gintas_ce
